Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-10-2009, 12:43 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Inconsistent RPMS
As you guys may know, i "think" i have some head gasket issues. It doesn't idle as smooth as it should. And now, it seems like it does it more, so much that this morning when i started it "cold" it sounded like i had a cam in it lol..sounded pretty sick too, until it stalled when i got into the street (but thats solely because it was cold). And NOW i notice RPM fluctuations when i'm on the gas "which never happened before" especially between 1700-2000 RPMs so whatever the problem truly is it must be getting worse. Anyway i just thought i'd post this, even though i already know its going to take some serious digging into the engine to get this thing fixed. Ahh well, its a labor of love i guess.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 09-10-2009, 04:06 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Inconsistent RPMS
You may want to do a compression and cylinder leak down test.
Sounds like it could be valves or a serious vacuum leak.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 09-10-2009, 06:03 PM
bhw33191's Avatar
Already did a compression test, guess you didnt see the post. But basically one side of the engine was stuck in the "red zone" according to my gauge and never left about 95-100 psi, whereas the other side of the engine had upwards of 140ish.
One more IMPORTANT thing to note, i just noticed this, but when i start the car up cold i can hear this ticking noise almost like an exhaust leak, once the engine warms up it goes away so i'm assuming this could be the head gasket.
Old 09-12-2009, 03:11 PM
Blt2Lst's Avatar
Sorry, I have not been following the saga of your car.
Sounds like it's time for a tear down.
While you are at it, you should probably change timing chain and gears.
1992 Camry LE 2.2
1996 Suzuki RMX250
