Old 09-09-2009, 10:43 PM
st8pipe350 st8pipe350 is offline
Exclamation fuel problem
89 s10 2.5L 5spd.
well as soon as i turn the key to the ON position. gas starts pouring into the tb. replaced the tps and it quit. but now i have no power to my fuel pump.. it primes... but nothing comes out... any ideas?
Old 09-10-2009, 08:53 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: fuel problem
Originally Posted by st8pipe350 View Post
89 s10 2.5L 5spd.
Does the pump run on start or engine run.
Check fuel pressure with fuel pump running.
Good 12 volts to fuel pump and good ground?
With good power and ground and no fuel pressure chech for out of gas and or fuel filter pluged.
Report back what you find.
MT
Old 09-10-2009, 12:47 PM
Re: fuel problem
its got gas, pump doesnt run on start up. runs on the ON position. checking pressure soon. 12v power is good. and ground is good. that was our first thoughts so we ran new wire.will report fuel pressure when i get back. thank you.
Old 09-10-2009, 06:07 PM
Re: fuel problem
ok, fuel pump is fine. but the injector has NO power to it... fuel was 13psi
Old 09-14-2009, 11:27 AM
MT-2500's Avatar
AF - Advisor
Re: fuel problem
Check fuse for injector power.
MT
