Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 09-09-2009, 10:37 PM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
EGR Valve
I have a 2002 Pontiac Montana. I need to know if there are any tricks or tips on removing and replacing the EGR valve. Any help will be greatly appreciated. Thanks
Old 09-10-2009, 10:00 PM
roadrunner2 roadrunner2 is offline
Re: EGR Valve
Acquire a new one.
Disconnect the electrical connector to the valve.
Remove the EGR mounting bolts (2), remove the valve and gaskets. Discard the gaskets.
Use a scraper and clean the valve gasket surfaces.
Installation is the reverse.
The problem with doing nothing is not knowing when you're finished.
