Cylinder head removal and engine coolant drain bolt
I have a '91 Accord which has a burnt valve so I am removing the cylinder head and having a pro do the valve job. I am running into a problem with the engine coolant drain. I can not locate the engine block drain bolt but have drained the radiator of coolant. Do I definitely need to drain the engine block of coolant or is just a radiator drain good enough to proceed with the head removal? Thanks for the help
Re: Cylinder head removal and engine coolant drain bolt
No need to drain the block.
Just make sure you remove any coolant that might get in a cylinder when you pull the head...coolant is poison to o2 sensors...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
Hey ouroboros314,
How did your cylinder head removal go? Did you need to remove the timing belt/ both timing belt covers to get the head off? (upper and lower cover) I'm to the part now where I'm trying to figure out if I need the lower cover off to access everything to get the head off the block. Any help would be appreciated. |
