Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-05-2003, 06:23 PM
nimrod nimrod is offline
Question How do I program a 2000 pontiac montana pk3 key
Old 08-23-2003, 10:26 PM
losmorans losmorans is offline
PK3 Key Programming...
Go to a locksmith and not a dealer. My dealer wanted $85 for a additional PK3 key for my 1999 Montana. I saved $50 by purchasing the new blank and having the original "cloned" at the locksmith.
Old 08-24-2003, 06:48 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
I have a tool box drawer full of aftermarket PK3 keys that failed to start the car,then couln't get them to start till I cleared the codes and sometimes had to relearn the theft system.
You get what you pay for!! The GM dealers do not charge 85 dollars for a key!! The PK 3 keys are around 50 dollars each.
To program your key first use a known master key that works.
1. Start the car
2. Shut off the car remove the key
3. Stick the new key in turn it to the run position
4. Wait till the security light goes out. Might be faster than you can see.
5. remove the key and try starting it with the new key.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 09-02-2003, 11:35 PM
Tana Tana is offline
Flatrater..no diss but is it really that simple. I'm new to Montana (2000) and only have one key. Was looking at purchasing another and they told me key was $70 Can and programming another $20.
Was told I couldn't do it myself, need some tool or something.
Old 09-03-2003, 07:20 PM
Flatrater's Avatar
Main GM Guy
Yes its that simple!!! I believe that GM even gives you directions in your owners manual on how to do it!!
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 09-10-2003, 12:28 PM
Ok sounds good. So I'm thinking that I'll purchase a key blank and have it cut and then program myself. HOpefully this should not cause me any problems....I hope??
My only concern is that a dealer told me that I need to have all the keys to program it properly (that is if I had 3 keys than need them all) or it would not work right. I only have 1 key since I just bought it used and only got one key and 1 remote with it. There may have been another key but I don't have it.
Should this be a concern and therefore I shouldn't try it myself?
Any help greatly appreciated. Thanks.
Old 09-15-2003, 06:22 PM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
I think you'll need just the keys that you want to work. They should be present when you do the programming thing.
Keep pestering me for those pages. Soccer season is upon me, and I'm pretty scatterbrained right now!
Old 10-22-2003, 05:56 PM
BOOZER BOOZER is offline
Re: How do I program a 2000 pontiac montana pk3 key
Passkey3 keys are easy to program.
#1= Buy key & have it cut
#2= Insert orig in ign & cycle to run poss, eng off
#3= Remove key
#4= Insert new key & do the same
If you did it correctly it will start & run, if not it will
start, run & shut down in about 10 seconds.
If it does shut down, you did something wrong. Dont
play with it or it will go into lockup & that takes about an hour before it will unlock itself.
Old 06-03-2004, 06:34 PM
SN95GT50 SN95GT50 is offline
Boozer,
Nice instructions, I just did it on my 2003 Silhouette, worked like a charm.
Thanks,
SN95GT50
Old 07-14-2004, 10:30 PM
navman911 navman911 is offline
Have any canadian owners managed to program their new blank with only one key? In the owners manual it says canadians need 2 keys to program. I just ordered a blank of ebay.
Thanks and hopeful
Old 11-26-2005, 09:24 AM
greganddonna greganddonna is offline
Re: Re: How do I program a 2000 pontiac montana pk3 key
#3= Remove key
Hi
Thanks for this post I tried it and it works great! Before the engine would just start and die and now it doesn't do that but the security light does stay on, is that normal?
Thnaks Greg
Old 08-15-2006, 07:03 PM
internetautomart internetautomart is offline
ok, I read the above.
What do I do since we lost our only key?
we got a key cut from the dealer, but the car doesn't respond.
we tried the instructions the dealer told us and all we got for it is a dead battery
Old 08-16-2006, 08:22 PM
ryanjenna ryanjenna is offline
I did mine with just the one key..worked for me Iam from Ontario
Old 04-24-2007, 02:34 PM
remo07 remo07 is offline
Thumbs up Re: How do I program a 2000 pontiac montana pk3 key and another problem.
Ok.. I read how to program the PK3 Key.. One more Question... When the vehicle engine start, the SECURITY indicator, Off ?? or it is permanently ON..??
This question is, because my Car is a Bonneville '02, Start with my Key, but, when I shut it down, it don't restart... and I very worried about that, because nobody can find the problem.
I appreciate all your partial or complete information about the problem...
Best Regards.!
Eddie Reyes.
Old 04-26-2007, 07:23 PM
ProAc_Fan ProAc_Fan is offline
Send a message via AIM to ProAc_Fan Send a message via MSN to ProAc_Fan
Thanks and hopeful
Funny it doesn't say that in my Canadian manual for my 05 Montana. As long as you have one programmed key you can program another one. P3 blanks can be had for $20 USD and you just have them cut at any locksmith ( $2-$3). I know Canadian dealers who will gouge you for $120 CDN for a replacement key.
Mike
Closed Thread
