Old 09-09-2009, 12:06 PM
weber45ca weber45ca is offline
99 GA SE v6 alternator rebuild
Hello,
Does anyone knows the bearing numbers for the inner/outter bearing on an original AC delco alternator?
Mine is really noisy, but it's working OK.
Thanks
Weber
Old 09-09-2009, 09:04 PM
Gir-_-'s Avatar
Gir-_- Gir-_- is offline
Send a message via AIM to Gir-_-
Re: 99 GA SE v6 alternator rebuild
Originally Posted by weber45ca View Post
Hello,
Thanks
Weber
in for part#s .. mines making a crazy rattling noise, but still works
It's been doing it for about a year now, and just sorta dealt with it...
04' Mazdaspeed Miata - GT2860 @ 10psi
99' GRAND AM SE V6H.O. 188whp - Sold
Old 09-09-2009, 10:15 PM
wafrederick wafrederick is offline
Banned
Buy a good reman alternator with the old one on hand for a core and do it right the first time.No one rebuilds alternators anymore which is a huge waste of time.Most parts stores will tell you this
Old 09-10-2009, 11:05 AM
Gir-_-'s Avatar
Yea, I know of one place locally here. They do some rebuilds. Small shop
Old 09-10-2009, 02:06 PM
Banned
Plus a good reman has a better warranty avoiding AutoZone and Advanced for one.The alternator might go out after the bearings are replaced.It is easier to get a reman,put it on and you are done.You have lots of wated time taking all apart and you have to figure out what parts goes where
Old 09-10-2009, 02:53 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Hmmm....... I disagree on this. I have rebuilt quite a few GM and Ford alternators. Often, I can get a complete rebuild kit (bearings, brushes, regulator and/or diodes) for about $35. Including electrical testing of all componets, I can rebuild it in 15-45 minutes, depending on how corroded the screws are.
A reman Ford or GM unit usually costs me about $150 on average. So the savings are substantial, for just a small amount of work, so its definitely worth doing, so long as the parts are available.
Sometimes, if the regulator or diodes are gone, but the bearings are good, I simply replace the one offending component, for about $10-15.
I only get a reman if the housing or armeture is damaged.
Old 09-10-2009, 04:42 PM
Banned
It is not worth the time to me and getting a reman is the easiest way.I do not have the time to do it and is not worth it.Price of labor is higher to rebuild it than get a reman.The price of core alternators is low,about $5.00 each for a core buyer to buy.
Old 09-10-2009, 10:02 PM
Banned
You cannot get bearings for them even cross referancing the original part numbers on the bearings.Tried and one parts store,a Carquest showed no bearings for them
