Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-08-2009, 08:26 PM
mrpx mrpx is offline
1995 cutlass supreme failing fast please help
i have a 1995 olds cutlass supereme 3.1 liter auto trans. first and most important the car starts and stalls hot or cold, stalls when comming to a stop hot or cold, intermittantly but increasing in frequency will not crank or start, only buzzing noise from fan relay 1 and dash lights will dim. checked batter and charging sytems performed voltage drops on b+ and B-, and all checks out. found starter solenoid b+ terminal stripped and cable loose. replaced starter and cleaned all connections. car still no crank no start. r and r ignition switch, still same problem. car acts like it has a short to ground some where. did notice recently once car did start ac compressor was noisy and metal was flecking off. second abs and parking light warning lights are on nand brake pedal is very hard yet i do have vacuume assist. brake booster check valve is good and i am getting vacuum to booster. can't find any vacuum leaks, wheel speed sensors ohm out same left to right, third brake light bulbs are both brand new. and lastly coolant light flashes even after bleeding cooling system and replacing coolant level sensor. help please i don't want to send this car to its grave.
Old 09-09-2009, 10:52 AM
maxwedge maxwedge is offline
A990 racer
Re: 1995 cutlass supreme failing fast please help
I'd start by geting it to run, no one here can diagnose all these issues on line. Do you have 12v to the starter solenoid when starting, does the security lite on the dash stay on? Are the battery grounds and connections clean and the cables good? Voltage checks may be ok but not when they are loaded.
Old 09-09-2009, 08:19 PM
the car now runs didn't do anything special. i think that the ac compressor was locking up and causing high current draw when trying to start. have tried to reproduce no start and have not been able to reproduce no start since ac compressor finished spewing metal from clutch\pulley. found coolant leak hose on radiator fill neck. haven't fixed leak yet all i need is a clamp and the 5 min to fix. i still think even after fixing leak and bleeding coolant that the coolant light will flash.
Tags
abs , car , lights , stalling
