Old 09-08-2009, 07:19 PM
goser goser is offline
No Fuel
Hey all, need a little advice tonight. With the exception of almost stalling at idle earlier today, truck has been running fine until sitting for a few hours tonight. Just tried to start it, no fuel pressure! No pressure and no noise from it when key is turned, but gives out a whimper when key is turned off. Swapped F/Pump relay with fog light relay, no change. Can't find test jumper wire.
Is it safe to assume that the fuel pump is toast or is there something else I should be looking for?
Thanks,
Guy who wishes he'd replaced the fuel pump when he replaced the tank and not now, after a fill-up.
'01 Chevy Blazer ZR2 4x4 VIN=W
'80 Yamaha XJ650 Maxim
'08 Jeep Patriot 2.4L
Old 09-08-2009, 11:23 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: No Fuel
Try smaking the tank with a rubber mallet about in the center under where the pump is mounted while somebody cranks it. If it start its almost a guarantee that the pump is bad.
Old 09-09-2009, 09:31 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: No Fuel
Thanks,
NO do not throw parts atr it untill proper testing done.
If pump does not run check for power to it and good ground.
Jumper fuel pump with a 12 volt jumper and make sure you have a good ground.
If no run then you can be safe to replace it.
MT
Old 09-10-2009, 07:41 PM
Kgal59 Kgal59 is offline
Re: No Fuel
"Try smaking the tank with a rubber mallet about in the center under where the pump is mounted while somebody cranks it. If it start its almost a guarantee that the pump is bad."
LOL, I just had a mechanic tell me that's a normal thing they do to check if the fuel pump is bad. The mechanic said it isn't a fool-proof test, but it's worth a shot. So, if it counts for anything, I second what this guy said. Couldn't hurt to try.
Old 09-10-2009, 10:50 PM
Airjer_'s Avatar
Re: No Fuel
On GM's it has a ruff success rate of 75%. It makes it a lot easier to get them into the shop as well!!
Don't bother on a ford. The plastic insulation around the windings melts and literally seizes the pump to the brushes/magnets.
Sometimes it will work on dodges as well.
Old 09-11-2009, 07:14 PM
Re: No Fuel
Well I didn't smack it with a mallet but that would've been handy if it hadn't died in my driveway. I figured the death wimper was sufficient evidence that it was getting power, so $400 later and I'm back in business! Kinda scary heat shrinking the wire harness near the exposed fuel lines lol!
Old 09-11-2009, 09:34 PM
laxman21's Avatar
laxman21 laxman21 is offline
Re: No Fuel
I had mine installed for about $500.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
