Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-08-2009, 07:13 PM
bigd7315 bigd7315 is offline
Send a message via Yahoo to bigd7315
rear sitting lower than front
I have a 88 gt convertible 5.0 auto what causes the rear to sag and what is best fix open to suggestions
Old 09-10-2009, 10:30 PM
Franco2112 Franco2112 is offline
Re: rear sitting lower than front
Sounds like it needs new shock absorbers. They did equip some 5.0 with adjustable shocks. You will have to look at them to be sure. If they are, your pump to them may be bad as well as the shocks.
Old 09-11-2009, 10:20 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Shocks would not affect right height. The springs are what would need replacing if it is sagging. You;d probably want to replace both at the same time anyway if you are replacing the springs.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
