Old 09-08-2009, 06:28 PM
bigsharks6 bigsharks6 is offline
Heater wont work
i have a 2001 z71 5.3 and when i turn the control knobs to the heat, it blows only ac, just replaced resistor. what else can it be?
Old 09-08-2009, 07:25 PM
j cAT j cAT is offline
Re: Heater wont work
both hoses to the heater core must be hot ... if they are not both hot, it is clogged...did you ever blow/flush out the heater core ???
Old 09-09-2009, 06:45 AM
not yet i found the other post a few pages back im going to check everything that was reccomended there today.
Old 09-09-2009, 12:53 PM
kahjdh's Avatar
kahjdh kahjdh is offline
see if your blend door actuator is moving, mine sticks sometimes.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 09-09-2009, 05:48 PM
how do i do this?
both hoses are hot, i dont hear anything happen when i turn the controll from cold to hot, so im thinking eaither that door is frozen (after all im in south texas and it really never gets below 50) or there no power getting to that door. how do i start checking this?
Old 09-09-2009, 06:52 PM
the heater hoses both hot going into the fire wall means coolant is flowing in the heater core...
as mentioned before the temperature blend DOOR is not working...this is a step motor that has 5volts dc applied to it and this motor moves this door to allow air to pass thru the heater core....this door can stick,,,maybe is loaded with texas dust....out here where I'm at it would be leaves,and pine crap...
so this means you must open the air box under the dash directly above the center trans hump,,,this is where this motor and then the internal door can be checked out...
you got filters in that air box,,,if not all the greater chance for this to occur..................
Old 09-09-2009, 07:01 PM
whats the best way to access this? do i need to start removing the dash and what not? or can i access it like i did the blower resistor.
Old 09-09-2009, 07:27 PM
the whole dash must be removed,,,this is a real PITA....
doh not what i wanted to hear... k i will wait untill this weekend to work on it... here we are in the worset drought ever, and it is finally raining after 9 months of not a drop of rain....
Old 09-09-2009, 07:38 PM
that post that stated the dash,,, must be removed is not correct ,,,,I made a mistake ,,,,it is possible to get to it by removal of the plastic directly over the hump area of the ducting...you will see when you open this area up not too hard...
Old 09-09-2009, 08:36 PM
i have bucket seats in the truck, so would i be removing the plastic console, like where the tape player is, around that area? what is the part called so i can search it online so i know what im looking for.
Old 09-10-2009, 06:17 PM
I have the same console in the middle ,,between bucket seats...
temperture door control...you most likely will find debris in there interfering with the door..most likely that door never sees the movement to the heat mode position where you live..
