Old 09-08-2009, 04:15 PM
savatage savatage is offline
Exclamation 04 cavalier miises or jerks
I have an 04 cav with 178000 miles. It will miss or jerk during acceleration and while maintaining speed. It will also sometimes die when slowing down to stop. The tach juumps up and down during. I have already replaced the plugs, fuel filter, fuel pump, cap with coil packs, boots and module, and tried injector cleaner. The check engine light never comes on. Any help would be appreciated. Thanks.
Old 09-09-2009, 03:20 AM
manicmechanix manicmechanix is offline
Re: 04 cavalier miises or jerks
What kind of transmission doesn't it have, an 4 speed automatic? I'm not sure what year was the last for the 3 speed. Actually it would help if you listed your powertrain. This sounds like it could be an AT problem, the lockup torque converter or the transmission itself going out . Probably want to check the fluid level and drain and change the filter if you haven't already. It's long over due.
Old 09-09-2009, 02:02 PM
trans is auto, 2.2 ecotec, not sure on the powertrain
Old 09-09-2009, 04:48 PM
It's probably the 4t40 4 speed. If you have over-drive and no trans dipstick that would be it.
Old 12-15-2009, 02:01 PM
joeuser742 joeuser742 is offline
It's probably the Torque converter solenoid. I had this go out on my 88 cavalier, and now am having the same signs on my 2002 cavalier. Soon you will start the car, put it in gear and it will die.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
