Old 09-08-2009, 11:20 AM
stormer_GS's Avatar
stormer_GS stormer_GS is offline
Porsche 934 RSR (no sponsor yet)
Hello again!
After I got tired of looking at the 1/24 911 '88 turbo without the Fuchs wheels I decided to give it a try
with a serious transformation into 934 RSR.
I'll make it fully open if I'll have the nerves for it, of course. Modifications started with the side mirrors
which were horrible. I couldn't make a quick bild so I said: "why not?? " and found a perfect "big brother"
to look at - the 934 RSR.
Here is the engine cover opening:
I will use the chassy engine for basis because it looks good enough from the bottom side - the top is up to me...
This is the turbo I intend to use for the 6-cylinder air supply:
Because I don't have the engine room, the engine build is on hold:
I grinded of the shocks mount to make an easier firewall mounting:
Then I made the shelf (top of the engine room) to make myself some guidelines for the engine build.
Because I needed the sides of the engine room, I cut out the drivers doors. I think it'll be easier to make
the sides of the interior in one piece (from engine to the doors).
Shelf is the weekest part at the moment but it'll be just fine when I mount the sides of the engine.
Old 09-08-2009, 04:20 PM
da_ashman's Avatar
Re: Porsche 934 RSR (no sponsor yet)
Nice work so far
Old 09-09-2009, 01:53 AM
Borjacho's Avatar
Borjacho Borjacho is offline
Bufff. Be careful, your knife becomes alive and it´s cutting your model by several sides
This project promises a lot. You must solve what your knife has cut
Put your kit in save before you find other panel cut...
Borjacho
Old 09-09-2009, 02:15 AM
klutz_100's Avatar
hej this looks like to be a fun thread to follow
Very interesting and intriguing start - looking forward to seeing more (hopefully someone will get the new post email notification system fixed one day )
Old 09-09-2009, 04:28 AM
jano11 jano11 is offline
Why not simply build the Heller (Esci) 934?
Old 09-09-2009, 07:35 AM
stormer_GS's Avatar
I didn't buy the Heller's 934 for many reasons like:
- it's price! The cheapest would cost me around 40€ with postage.
- incorrect or bad rims which have to be replaced,
- bad quality kit,
- because I had a 930 turbo at home and I got the appropriate rims from a friend (Tamiya BMW 635)
Thanks for watching and your comments!
Old 09-09-2009, 08:03 AM
Here: http://cgi.ebay.co.uk/ws/eBayISAPI.d...fvi%3D1&_rdc=1
And no I'm not the one selling it.
I agree with the rest of your reasons though.
I've got a project in mind and I'll build mine using the Esci body and the Fujimi chassis, interior and engine + some scratchbuilt parts to make it a full detail kit. That is when I'll have enough time for it.
Still I'm looking very much forward to see your work on this mod.
Old 09-10-2009, 04:26 AM
stormer_GS's Avatar
Thank you for pointing out this cheap Heller jano11. I was two hours late for that one but I don't
think that I would actually buy it because of the economical reasons. My stash was growing until
6 months ago when I realised that I have collected enough material for 15 years of building. Most of
it has low detail level which means they will be "time eaters" but the rest of the stash includes well made
models (Accurate miniatures, Gunze, Rememoratrise) that also deserve special treatment at build...
Sounds like a neverending story.
I'll try and make my mods detachable from the original kit to cast them and use them for other sponsor versions of 934RSR.
Old 09-10-2009, 06:23 AM
You're not the only one. I think I have enough models for my whole life, even for a very very long one.
That sounds like a great idea. Looking forward to see more of your work.
Old 09-11-2009, 03:47 PM
stormer_GS's Avatar
Here is a small update of the interior. I removed the original "back seats" from the chassy and started
to make my own.
This is the stage before putty therapy which will fill all of the small gaps and
after sanding hopefully show some more resemblance to the original interior on the fourth photo.
The change is also visible on the bottom side of chassy when I compared it to the old photos.
Old 09-12-2009, 03:25 PM
stormer_GS's Avatar
The rear seats are filled and waiting for the putty to dry up. That's when I'll hit the sandpaper and
take away all of the excess putty and make some structure on the bottom of the "seats".
I also made a photo of the bottom side of the chassy so that you could see what I was writing about in
the previous post.
The twisted yellow things are masking tapes wrapped around the chassy so the putty wouldn't stay
on the chassy (where the rear swingarms are mounted).
Old 02-23-2010, 06:24 PM
stormer_GS's Avatar
Here I am again going forth with this build of 1/24th Porsche 934 RSR.
This build has been stuck because of the finish on the 1/24th Lexus IS350
I was working on for past few months.
I was tired of painting so I thought of this Porsche which quickly
remembered me that it's all about scratchbulding here.
I simply felt the desire to cut some styrene so that's why I cut
off the hood. It took me a few minutes because I finally bought the right
tools (Crazy Modelers large saws that fit into small Olfa knife)...
The next thing to cut were the sides of the "luggage" compartment.
I used 1mm thick styrene to make the sides:
Because I want the front to look as real as possible I had to reproduce
the supporting shelf for the reservoairs and other usefull stuff. I sketched
some holes to get real looking proportions (at least I tried to do so ):
A bit of tease before unveiling...
TA-DA!
Of course I'm not making the trunk compartment up so that's why I'm using
this photo as a reference (restoration of Wollek's 934 from Freisinger Motorsport):
This is how it looks like now (still a loooooonnng waaay to gooooooo):
Thanks for watching!
Old 02-25-2010, 05:32 PM
stormer_GS's Avatar
This is today's progress and though I didn't spend too much time
on it (approx. 3hrs) it looks more attractive comparing to previous photos.
I also have to think in advance because every modification of the trunk
("firewall" if referred as the front mounted engine model) shows in the interior.
That's why I had to cut the dashboard to it's final dimensions to design
the trunk correctly.
I hope you understand what I'm trying to say - my English is bad...
Old 02-25-2010, 06:46 PM
bmwmech1's Avatar
bmwmech1 bmwmech1 is offline
Cool build, I'm liking the realism you're achieving with the scratchbuilding... looks great!
Garey
Old 02-25-2010, 10:04 PM
quadzero's Avatar
quadzero quadzero is offline
I really like all the work you are putting into this. Very ambitious project. The trunk compartment looks fantastic.
