Aux,Rad Fan.92 Lincoln Continental 3.8 eng
Aux (low speed Fan) inop; The Fuse in Power Box good;
I have no power at Fan when car reaches operating Temp; There are Two Relays on the outside of power box.I believe one of those is the Fan Relay;but not sure and this manual does not show it; There is a Relay Fan Module mounted on fwd metal ;This is the High Speed Fan that is engaged when cold air is selected and Comp. Clutch is engaged; Any help appreciated Update;Thursday Sept 10 Replaced the C.C.R.M. (Fan Relay) No Power to Fan ; I saw a Note about a Fused Link in Power Supply,must be under the Batt;Will check it tomorrow. Last edited by ringo7; 09-10-2009 at 10:55 PM. |
Re: Aux,Rad Fan.92 Lincoln Continental 3.8 eng
Hey, the Ingegrated Relay Control Module is located at the right front corner of the radiator support bracket. There should be 6 relays in there, label says EDF. If not labeled, the wires according to the schematic should be brown/orange and black/orange. As a note, according to the book, the low speed fan isn't supposed to turn on until 215 degrees and shuts off at 210.
