Pulling the fuse (fuel pump)
I changed my fuel filter the other day and relieved the fuel pressure by pulling the fuse to the fuel pump. I was surprised that the engine died almost immediately. When I did the same thing on my wife's Escape a couple days later, that car took over a minute to finally die. Is it normal that my car died so quickly?
2001 Grand Prix GTP S/C |
Re: Pulling the fuse (fuel pump)
yes.
I am more worried that your wifes ran for a minute with no fuel pressure. If it worries you, you can always just rent a fuel pressure guage and check fuel pressure at the Rail. Although I'm betting it is just fine.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Can someone point out where the fuse is located (inside the car or under the hood) and what the amperage is? Someone stole my manual when I took the car to have it sprayed.
I usually just yank the fuel pump relay. Its under the hood, you will see which one it is under the fuse box cover. I think you only have one whereas older GTP's have a fuel pump relay and a fuel pump speed relay.
Thanks for the info. I found it.
