Old 09-06-2009, 10:33 PM
4x4 blazerguy 4x4 blazerguy is offline
Smile Radiator failure ????
The other day the wife came home & I smelled anti-freeze, (not normal) Upon checking I see the radiator is split on the side were the P/S pump cooling lines goes into the radiator.
My question is how many of you have had this problem or heard of it???
Old 09-06-2009, 10:48 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Radiator failure ????
The power steering lines do not go into the radiator. You have your choice of transmission lines or oil lines. If you talking about the tank leaking where the fittings for the cooler are on the radiator its pretty common. If your talking about the tank itself physically splitting that's not uncommon either. If you're talking about the tank separating from the core that's not that uncommon.
Old 09-07-2009, 10:21 PM
I'm sorry oil lines. The tank split on the end by the fittings. Thanks for the input.
Old 09-08-2009, 07:52 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Year make and engine and mileage?
Most good parts places offer new replacement radiators to fix your problem.
Also a good time to do a good coolant fush and coolant hose and belt service on it.
MT
Old 09-09-2009, 12:26 AM
1997 Blazer 4x4 4.3 V-6 120,000 miles. The reason I ask is I have heard this is a common problem. I just wanted to know if that is true.
Old 09-09-2009, 09:27 AM
MT-2500's Avatar
AF - Advisor
If it makes you feel better join other people with rad cracking.
Plastic tank breakage or cracking is a common problem on any 8-12 year rad.
Some just last longer than others.
The fix is a new rad.
Letb us know how it goes.
MT
