Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 09-06-2009, 09:10 PM
Experianced2 Experianced2 is offline
Engine dies out when running.
I have a 2000 Town Car that has never run right since I got it last year. It's engine dies out when running under power at most speeds.
The engine keeps running but has no power and will not keep up speed. It just runs at idle. It will only recover if the ignition is shut off and then turned on again.
The car has been in a garage for months! They have replaced the fuel pump, injector work and now a new computer has been put in and programed and still the engine dies out!
What to do? Please help.
Old 09-08-2009, 12:24 AM
L-dogg ROLLER L-dogg ROLLER is offline
Re: Engine dies out when running.
i doubt it, but how about a fuel filter? by dies out do you mean it stalls? (just trying to ascess your description) when the motor "dies out" does it sputter/hesitate?
or is it more like the motor keeps running fine but the car just stops accelerating? when it does that does the motor's rpm's increase?
97 lincoln town car signature
Old 09-08-2009, 12:05 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
Have your cats checked. Do you have a Rotten Egg scent?
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 09-11-2009, 10:34 PM
Thanks for the replys. When going 72 mph on the highway the engine will suddenly only put out enough power for an idle. Pressing on the gas pedal does nothing. The only way to get it to recover is to turn off the ignition and restart it.
The garage gave me the car back five days ago and I drove it 600 miles and it died out five times.
I brought the car back to the garage (again) and they read some codes and are now guessing that maybe its going into what they call a "failsafe mode" due to some transmission irregularity.
They have the car again.
Old 09-12-2009, 07:23 AM
danielsatur danielsatur is offline
If engine isn't performing, it could give symptoms of a bad Transmission irregularity!
Need good HP for constant hydraulic pressure for transmission.
I have seen plugged catalytic converters choke out 4-cylinder engines, but CAT's usually blow out on V8's, thus ECU will throw codes p0420/p0430.
Some newer cars have a cable less throttle body and when dirty will give the same symptoms.
The elctronic control module on the throttle body will lose control of the throttle plate, from being strickey of PCV+EGR gunk.
Lincoln service would charge $2K for a new throttle body,or you could buy a used cleaned throttle body on ebay for $200.
Using a micro cloth,WD40,and fogging oil to clean throttle plate + exercise by hand.
During this Throttle body cleaning, it's a good idea to clean your MAF sensor with
MAF sensor cleaner.
Caution - don't use a harsh carb cleaner,because it will strip protective coating and damage seals on your throttle body.
Cable throttle body back in March and found lost HP,see
http://www.automotiveforums.com/vbul...d.php?t=949299
more
Electronic Throttle body back in Jan and found lost HP,see
http://www.automotiveforums.com/vbul...d.php?t=882939
If School book Technicans go by the book,you could be throwing to much money @ the problem for root cause!
Only pay for Root cause!
Someday you might beable to sue a shop for being husseled or malpractice.
Old 09-13-2009, 04:16 PM
Kitt1993's Avatar
Sounds like the transmission is going into Limp Mode. I would have it checked. out by a tech. Also dont listing to Micgiver, hes the neighborhood idiot.
The President,
Lucky Number 5
Old 09-13-2009, 05:15 PM
Focus on the Issues, not personal Attack's.
What elements do you need to keep a good burning fire?
LOL- & throwing money @ the problem don't count.
Engine deliverability Issues:
Air Intake,Fuel,Ignition timing,and exhaust!
Whats the most normal wear + tear + NEGLECTED ?
1) Air Intake- Bad Air filter,MAF sensor,IACT sensor,dirty throttle body,or O2 sensor.
2) Fuel- Bad fuel,Fuel filter,injector, or Fuel Pump.
3) Ignition timing - Bad plugs,wires,or COP's.
4) Exhaust - Plugged or bad catalytic converter.
A bad electrical signal from a electronic accelelator pedal to the electronic contol module on throttle body can trigger a Limp mode!
LOL - I have seen + heard technicans diagnose a bad Transmission and charged the customer for both tranny + throttle body.
WOW!
The shop already had his car for a few months.
This is a perfect case, were cash for clunkers $4500 + A new car would of been the better deal.
Old 09-14-2009, 10:39 AM
Kitt1993's Avatar
But its NOT your decision or the Government's to make Mcgiver Its his and should be his. More power to him.
Small Government.
Big Business.
Freedom.
Not Socialism.
The President,
Lucky Number 5
Old 09-14-2009, 04:36 PM
Dude - Check craigslist for BS forums, this is about fixing Autos without getting husseled and raped.
Be part of the solution not problems!
1) Profile car by the year, make, and mileage.
2) Know whats the car worth bad, befor throwing money @ it.
3) Use NADA and KBB minus the repairs.
3) Get a 2nd & 3rd opinion on repairs.
4) Use Automotiveforums search tools, befor creating a new thread.
Old 09-21-2009, 10:00 PM
regragg regragg is offline
the turkey shoud have set some kinda code by now. may have a bad relay or i. switch run search to see if your,s is one that they are having a run of bad parts allmost all mlf. have had runs of bad parts.
Old 09-22-2009, 09:58 AM
2000 TC /120K Miles
NADA
Average Trade-In $3500 / Clean Retail = $6900
Minus
FUEL pump/Filter -$500
Injector service -$500
Computer -$1200
Transmission -$3500
Total= $5700
* There is still no guaratee, that your problem will be resolved.
http://www.StopRepairBills.com
Extended warrenty program might be a good idea for a mature car in your case.
