Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 09-06-2009, 09:07 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Rear Caliper part numbers / Brembo Factory caliper rebuilds
Does anyone know the part numbers for the rear brake calipers? Thanks.
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 09-06-2009, 09:13 PM
panozracing's Avatar
panozracing panozracing is offline
Re: Rear Caliper part numbers?
i dont know the part number........but i have a brand new one if you need one....
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 09-06-2009, 09:38 PM
jmimac351's Avatar
Hey Brian, I remembered that and just sent you an email to check on that. I thought I had my problem solved but it keeps flaring up on the track. Really annoying.
By the way, I came across a Brembo Caliper Service offering by Brembo in Mooresville, NC. Apparently they rebuild / test calipers back to factory spec. No idea what they charge but it might be handy down the road.
http://www.brembo.com/US/RacingProducts/CaliperService/
Here's a pdf about it:
http://www.brembo.com/NR/rdonlyres/2...INGpersito.pdf
Jim McGovern
Pictures
Old 09-06-2009, 10:00 PM
jmimac351's Avatar
Brian, I sent an email to you here: [email protected]
Jim McGovern
Pictures
Old 09-07-2009, 11:13 AM
PanozDuke PanozDuke is offline
Jim,
I don't have any of the Brembo part numbers for the calipers (I'd sure like them for inclusion in the Tribal Wisdom), but the PAD GTS parts manual lists the LR caliper as GTS2-4207. I believe they are the same as on the GTRA and GTWC cars, but they would know that for sure. The rotors on the GTS are Brembo, but I believe they are same size as our PFC's with different mounting hardware (expensive conversion). This is why I believe the calipers are the same. I'm not certain, but there may be a recent upgrade to the calipers from PAD for the GTS cars to help them in SCCA GT2 competition. Don't know if they go by the same earlier part number or not. Let us know what you find out on all this. Thanks for the rebuilding tip.
Mike
