Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-06-2009, 11:58 AM
laxman21's Avatar
laxman21 laxman21 is offline
What's the proper operating tempature
For a 99 burb 5.7. Mine runs about one light smaller line above the first larger line. What's that about 170ish or so.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 09-06-2009, 02:44 PM
j cAT j cAT is offline
Re: What's the proper operating tempature
this is the normal range..slight dif with the gauge is common...If the temp raises quickly then locks in at about 180deg f it is good...
my 5.3L runs at 190deg F and the thermostat is a 186 deg..
Old 09-06-2009, 07:26 PM
777stickman 777stickman is offline
My '98 7.4 runs about 1/2 tick above that on the gauge. I read that as around 185. The important thing is what the VCM see's from the ECT sender.
There are two senders. One for the gauge (drivers side head) and one for the VCM (front side of intake manifold).
The motor is designed and recommend for a 195 deg t-stat for the VCM to control fuel and timing.
Lots of guys run 180 t-stats without problems.
If you want to know what the real ECT (Engine Coolant Temp) is you'll need a scan tool that can access that info. With a 195 t-stat it should be 192-198 no-load level driving.
J-Cat---Point me to where you got a 186 t-stat. I'd like to get some.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 09-06-2009, 08:20 PM
the T stat I got was from advance auto..it was the exact same as the OEM...almost on the design as it had a slightly different weep hole so coolant could flow when T stat is closed...about $20-25.oo...
it did produce the same exact operating temp as the original...still have the original for back up/ reference...
also the temp will lock in at the 190deg and thats it cold/hot outside no change once the engine is fully heated up...
this also has a lifetime warrantee...
you have a different engine so this may not be your correct T stat..
