Old 09-06-2009, 03:04 AM
g30rg3d4y g30rg3d4y is offline
92, grand voyager
it looks as if my key cylinder is broken as i cant turn my key anymore.
I want to take it to the shop but i dont really want to get it towed, so i am trying to hot wire it.
i have downloaded a wiring diagram (at the bottom of this post) and was wondering if anyone could help me with a step by step guide of doing this.
i will eventually be installing at a remote starter if anyone has any information on that, thatd be much appreciated thanks!
Old 09-06-2009, 09:57 AM
jpb53 jpb53 is offline
Re: 92, grand voyager
If the key won't turn then how are you going to unlock the steering column?
Old 09-06-2009, 04:15 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
thats what i always wondered in movies when people hotwire a car and go, haha. how to steer!
Old 09-06-2009, 04:18 PM
Goober
Anyway, you could consider just doing this yourself its an easy job. rent the steering wheel puller from autozone, buy the Key cyl pull the wheel and replace it. sometimes you will need to unhook horn wires, and be careful of the turn signal. im assuming no airbags on that year. prolly save a ton of money if you DIY.
i mean, its not much harder than just hotwiring it!
Old 09-06-2009, 04:36 PM
Thats weird.. i can still move the steering wheel though?
We had a key that wasn't for the car and had been using it for a while because for some reason it worked. We used the wrong key as usual and now when we went to start it using wrong and normal key, the wrong key wont go all the way in and wont turn and the normal key goes all the way in and wont turn. We have moved the steering wheel shitloads and rocked the car back and forth.
anything we may not have done to fix this?
and ok exalteduser should we be buying
http://cgi.ebay.ca/1991-94-Plymouth-...3286.m20.l1116
and then rent those pull devise and give it a go?
Old 09-10-2009, 06:25 PM
sorry for the bump guys?
anyone else?
