Old 09-05-2009, 10:34 PM
JOSH...BAMF JOSH...BAMF is offline
Evaporator drain tube leaking too much
My truck has been smelling like antifreeze for the last couple of days and today on the way home from work my low coolant light came on but the temperature stayed the same. On my way home I did not run the a/c at all and when I got home there was a steady drip of water coming from the evaporator drain tube with the truck running. I filled my reservoir up but am figuring it will leak out pretty fast. Anybody know what it could be? Or any way of narrowing down what it could be?
Old 09-06-2009, 02:35 PM
j cAT j cAT is offline
Re: Evaporator drain tube leaking too much
your heater core is leaking,,this is usually from insuffecient coolant which controls the corrosion...also the use of dirty tap water which has metals that attack the metal used in the engine/heatercore...if you live were heater operation is not required immediately,,,you must bypass the heater core by making a bypass pipe to connect the heater hose output from the engine together..rather than go to/from the heater core..
this will give you time to find a repair shop that can do this repair..
THE DASH WILL REQUIRE REMOVAL ....
Old 09-07-2009, 02:58 PM
jyount jyount is offline
Yes, bad mix can cause it, but I had to put a heater core in my wifes TB before it had miles or years on it, and it had never been changed, I think the general just had some crap heater cores for a while.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 09-08-2009, 01:28 PM
intimadatorsquizz intimadatorsquizz is offline
you need a heater core.
what year and all is your vehicle?
Old 09-08-2009, 02:41 PM
Just bypassed the heater core and it seems to have stopped leaking. Good thing I live in florida. The only thing I threw me off was that there was nothing leaking in in my cab but I guess there is a catch that leads to that drain tube. Thanks for the help guys.
Old 09-08-2009, 07:30 PM
now that you have this bypassed start saving for the expensive repair bill...if you get some repair estimates I'd be interested in the amounts..
good luck..
Old 09-09-2009, 01:03 PM
I don't plan on getting it fixed until it starts getting cold. I have a 99 silverado and will post the cost when I do get it done.
Old 09-12-2009, 10:19 AM
cramer_77 cramer_77 is offline
Do some shopping around i'd say, at my work that repair would cost upwards of about $450 not including parts and guessing you don't have any luxury items (ie console, onstar)
Heater Core
Replace
Main Heater
Without AC 3.9 5.5 Does Not Include: Refrigerant Recovery Or Evacuate & Recharge AC System.
With AC 4.6 6.2 Does Not Include: Refrigerant Recovery Or Evacuate & Recharge AC System.
NOTE
With Standard Console, Add 0.4 0.5 Notes
With Luxury Console, Add 0.6 0.7 Notes
With OnStar 0.3 0.4 Notes
With Three Piece Cover, Add 0.2 0.2 Notes
01 Silverado 2500HD, HID lows and highs, cold air kit, leveling kit, brush guard, dual flowmaster outlaw mufflers, 5% windows.
