Old 09-05-2009, 10:05 PM
aberlin1998s10 aberlin1998s10 is offline
98 S10 license plate light flickers with turn signal
I noticed this two days ago that when I'm in reverse(backing into driveway) that the passenger side back-up light was not on. After some investigation I noticed that when the turn signal is on, both back up lights VERY dimly light up, and the passenger side license plate light flickers with the turn signal. Also when the brakes are applied, the back ups come on very dim as well. I had just taken it to the dealership to have some fuel system things fixed up, so I'm not at all pleased. Driving me !!!
Old 09-05-2009, 10:29 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 98 S10 license plate light flickers with turn signal
You have a bad ground! When things just plain don't work its usually a power supply issue. If there is a lot of funky problems (dim/blinking/not supposed to be on) its almost always a bad ground.
