Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-05-2009, 12:21 PM
laxman21's Avatar
laxman21 laxman21 is offline
Radiator leak
Have a small leak on drivers side where the top oil cooler line goes into the radiator. Coming out from behind the black fitting locking nut.
Can this be fixed or do I need a whole new Radiator?
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 09-06-2009, 10:00 AM
777stickman 777stickman is offline
Re: Radiator leak
Is it a coolant leak or oil leak?
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 09-06-2009, 11:55 AM
laxman21's Avatar
Re: Radiator leak
coolant
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 09-06-2009, 02:50 PM
j cAT j cAT is offline
Re: Radiator leak
Originally Posted by laxman21 View Post
coolant
the driver side of the radiators crack,,,if the coolant leaks here there must be a crack...remove this connection to see if the side tank is n/g..
I have never replaced a tank on this radiator ,,,but the older vehicles this was possible and It was not expensive...compared to buying a new radiator..
some radiator shops do have the ability to use a product that can melt into the crack and repair the side tank...
Old 09-06-2009, 03:00 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Radiator leak
The original radiator, 10 years old, showing signs of failure, replace it!
Old 09-10-2009, 09:57 AM
spyder2000 spyder2000 is offline
Re: Radiator leak
This is a common leak point. Buy a good quality replacement (I recommend Delphi) and replace it. Some radiator shops can replace the tanks ends but by the time you r/r the rad and pay for the repair, you've probably got almost as much money in it.
In fact I will doing an r/r on my own in two weeks.
Old 09-10-2009, 02:43 PM
Cusser's Avatar
Cusser Cusser is offline
Re: Radiator leak
I had my '94 sub radiator replaced last year due to a sudden, massive leak, so 14 years for GM product, had coolant change at least every two years (with complete water flush out from the Prestone-type kit), figured OK for 175K miles.
I let my mechanic have this job, charged on hour labor ($85), and new replacement radiator was about $250, so not too bad. My experience with my suburban is that most times there are multiple parts listings for a certain part, and they need to be matched up. For example, when I needed a master cylinder, the parts guy asked what size my rear brake drums were, like how the $%^&#%&&$$%^ would I know, the Sub was at home, with the wheels on !!! So I let my mechanic do that job, then I just used that part number for cross-reference to replace that years later.
Old 09-13-2009, 04:54 PM
kpghia kpghia is offline
Re: Radiator leak
laxman21-
My son and I replaced the rad in one afternoon...after 155,000 miles I owed it to the truck. About $155.00 delivered from RadiatorBarn.com. Add in upper and lower coolant hoses and new coolant, around 200. Easiest job to date. Good luck.
Kevin
