Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 09-05-2009, 07:46 AM
ziggy2525 ziggy2525 is offline
2001 Tacoma 4X4 problem
My Tacoma is a 2001 regular cab 2.7L with a manual trans. The dash light indicating when my truck is in four wheel drive has gone out. Is the fact that the light has gone out mean that there is a problem with my four wheel drive system? Next question: Since the light is out I drove in four wheel drive at about 70mph for about twenty miles. Did I do any damage to the system? The low range still works but when in four high the truck does not hop on asphalt when i crank the wheel to either side, the traditional way of testing if four wheel drive is working. So I am unsure if the four high in my truck is working properly. Any help that could be given is greatly appreciated.
Old 09-09-2009, 08:36 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 2001 Tacoma 4X4 problem
Which type of 4WD system do you have?
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 09-11-2009, 08:32 AM
I am not sure what you mean by "what type of 4 wheel drive system I have." It is a manual system, not push button, with automatic hubs. I hope this helps and thanks for the interest.
