Old 09-04-2009, 07:48 PM
specialist specialist is offline
town & country 2000 park lamp problem
Town & country 2000 park lamp comes on only on the left side.No license plate and no instrument cluster illumination.I found a short on the wires going to rh front park lamp,fix it but no park lamp at the Rh.All fuses are ok.When turn park lamp on it take a few second for the only rh working to come on.
best regards
Old 09-05-2009, 04:39 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: town & country 2000 park lamp problem
Left and right side lights have individual fuses. I'd tripple check it. Right side shows a 15 amp fuse #3 but the fuse numbers on this schematic have been proven wrong in the past. Check your manual to be sure. Schematic shows a single power source from the Body Control Module (BCM) to the park lamp relay which powers all parking lights so I have doubts the BCM is the problem. Just incase the schematic isn't showing everything try pulling the IOD fuse from the fuse panel under the hood (PDC) for 3 minutes. This will reset the BCM. The BCM does have the lamp driver for instrument lighting.
The LP light is powered by the fuse for the left lights so we know the left parking lights fuse is good. Have you checked for power and ground at the light. How is the bulb?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 09-06-2009, 03:21 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
i was wondering if this just acts up when on parking lights mode, or even with headlights on too.
