Old 09-04-2009, 06:47 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Low Beam Conversion
I have seen some trucks driving around that when their high beams are on the lows stay on. After looking at the wiring diagram I see that if I just ground them it would work but since the high and lows run off the same fuse what are odds of burning something up?
I have a brush guard now and it inhibits the highs enough to where I cant see directly in front of me at night. Thanks
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 09-05-2009, 08:17 AM
gremlin96 gremlin96 is offline
Re: Low Beam Conversion
sounds like you have the wrong brush guard. a good fitting one will let all your lights shine so every one can see them.
gounding a light out will make a short you will blow a fuse.
Old 09-07-2009, 07:27 PM
kahjdh's Avatar
Its not shorting them, its just having both sets on at once. My question is if the bus bar in the fuse block big enough in that area so that it wont melt.
Current Cars:
Past Cars:
Old 09-08-2009, 01:25 PM
intimadatorsquizz intimadatorsquizz is offline
Hella makes a relay kit so that you can have all 4 headlights on at one time.you need to add a relay and a few wires but it comes in the kit.
i did it on my 90 k1500 4x4
Old 09-08-2009, 05:47 PM
kahjdh's Avatar
I have no problem wiring relays I was just wondering if there was an easier way b/c I plan on having a bunch of relays for accessorys(ie Kc Daylighters, elec cooling fans, HID headlights) and wanted to keep the clean look as much as possable.
Current Cars:
Past Cars:
Old 09-25-2009, 02:05 PM
silveradofirerescu silveradofirerescu is offline
Try searching for this. I seem to remember a mod where you just jumpered a wire and it completed the 4 light mod. I have it done to my truck. Also, if you look hard enough there is an 8-light nod where your fogs/drl/lows/highs all are on... looks sick!
Old 09-26-2009, 04:14 PM
sooperduty's Avatar
sooperduty sooperduty is offline
I've done this mod on my 2000 about a year ago with no probs. You add a jumper wire to the relay under the fuse/relay box under the hood.
Do a search on this.
2000 GMC SIERRA 2500 6.0
Old 09-28-2009, 03:17 PM
denco denco is offline
Here is the link to a 2006 (4 headlight mod post)
You can find it all here:
http://www.automotiveforums.com/vbul...d.php?t=513259
Old 10-04-2009, 10:26 PM
dougger dougger is offline
Here you go, I have done these on my old 2000 silverado, and then have done this on my 2005 and it takes less that 20 minutes for each.
1999 - 2003
http://www.automotiveforums.com/vbulletin/showthread.php?t=305179&highlight=4+headlight
2004 - 2006
http://www.performancetrucks.net/for...d.php?t=245919
Old 10-05-2009, 09:30 PM
OKCSuburban OKCSuburban is offline
so that is how they are doing it....cool thanks for the help
2000 Suburban, 4wd, LT, 143k. (Sold and missed)
BMW 318i Convertible, 996 Porsche, BMW X5, Silverado (sold) Honda Ridgeline.
