92 GM codes
I got some codes. Anyone know what I should replace? Running- 116. Engine off- 111, 176, 177, 542, 543
Re: 92 GM codes
By the way, one of the codes is the "flexible fuel sensor" Where in the world is that?
Re: 92 GM codes
116 is the coolant sensor is not reading correctly
176 and 177 are for the drivers front O2 sensor is both rich and lean. This usually indicates a bad sensor. 542 and 543 are for fuel pump has lost voltage sometime in the past. If a relay has been removed with the key on, it will set this code. You have no code for a flexible fuel sensor. Click here and go down to the 3 digit codes.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
Re: 92 GM codes
Thanks for the reply! Yeah, I should replace the 02 sensor. The engine light comes on for about 3-4 minutes, goes out, then runs rough for about 3 miles. It then runs smooth again till the next cycle of light, rough running, etc. Does that sound like 02 sensor? Btw, the drivers side doesn't have 02 sensors, just pass side....on mine anyway! Thanks again
Re: 92 GM codes
So you have a single exhaust? I am used to the CVPI dual exhaust. So if that is the case, replace the front sensor.
Re: 92 GM codes
Boy do I feel stupid! I didn't realize the 02 sensor was on the exhaust manifold! One on each side. I DO know however there isn't one AFTER the cat on drivers side. so I'll replace the drivers side and see what happens! Thank ya sir. Btw looks like ya got some good auctions. I might look into it in a few months. I'd love to have a p.i.
Re: 92 GM codes
It's amazing the diff a new o2 sensor makes!! Probably should replace other side for good measure! Thanks again way 2 old for your help.
