Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 09-04-2009, 01:38 PM
curtiszavodny curtiszavodny is offline
71 sputtering when engine is cold
I have a 1971 El Camino, 350 V8 5.7L w/Rochester 2BB carb, HEI ignition. Car was initially running a little rough, so I did the basic tune-up stuff to it.....new distributor cap, rotor, ignition coil, spark plugs & wires, re-set timing, changed filter in charcoal canister, new PCV valve.
The car is running good in general, but if it's been sitting for a while and the engine is cold, it sputters when given a light amount of throttle while driving. Once it warms up, after 5 - 10 minutes, the problem goes away. Does this sound like a carb issue?
Old 09-04-2009, 05:07 PM
relic7680 relic7680 is offline
Re: 71 sputtering when engine is cold
Sounds like a carb deal to me.....had an '80 LeSabre w/ the quadrabog that did that crap too. Maybe a rebuild is in order.
close enough for government work........
'91 C2500 Silverado (8600GVW)
'89 Suburban R1500 Silverado
'76 GMC Sprint Classic
'76 El Camino Classic
Old 09-04-2009, 10:00 PM
thanks for the reply. kind of what i was thinking....but didn't want to start doing stuff to the carb if unneccesary. did you rebuild yours when you had that problem or just replace it? this carb looks pretty old.
Old 09-04-2009, 10:35 PM
I never fixed it....the car was a turd and it ran good enough for me in high school. You could check out a Chilton's and see what exactly it says about your problem. Or talk to someone who really knows carbs. If you want to rebuild it.....kits are cheap.
Old 09-10-2009, 07:35 PM
cherryelky305 cherryelky305 is offline
Send a message via AIM to cherryelky305
dont rule out other possibilities either, if it runs fine when its warm, and rough when its cold then it might have something to do with vaccum. as the engine warms up it closes any gaps, and stops the problem. check over all your hoses and spray something around the carb when its cold to see if it changes the idle.
1980 El camino
2002 LS1 swap
Old 09-11-2009, 09:07 PM
manicmechanix manicmechanix is offline
It sounds like the carburetor is dirty to me. Probably your transition slot is cruded up some and leaning out the mixture and maybe your airbleeds. It might need cleaned out, and the idle mixture, speed and choke adjusted. Do you have your Snorkel heat riser hooked up, although I doubt it's cold enough for the choke and heat riser to be needed.
