Old 09-03-2009, 05:07 PM
cakes227 cakes227 is offline
4L60-e transmission for a 95 blazer
I need to replace the transmission on my girlfriends 95 4x4 blazer, can I use the transmission from any 4x4 vehicle that uses a 4L60-e or are there different models of the transmission for different cars?
Old 09-03-2009, 08:42 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
Re: 4L60-e transmission for a 95 blazer
im thinking that you can, call a junkyard and ask them, they seem to usually know what will work in what, (unless you get that douchebag guy on the phone that every JY has thats too lazy to help)
are you replacing the t-fer case too?
Old 09-03-2009, 09:38 PM
wafrederick wafrederick is offline
Banned
1995 has the flare nut fittings for the transmission lines.Starting in 1996,GM went to Jiffy Tite fittings which remove much easier with the special release tool and do not leak.1995 is by itself .
Old 09-04-2009, 01:08 AM
4x4 blazerguy 4x4 blazerguy is offline
Aren't the shifters different? the 97 up I know use a bottom to electronically engage Weren't the older models manual?
Old 09-04-2009, 05:20 PM
I suppose I will replace the transfer case seing as the 4x4 does not work.
So I have to get it from a 95 vehicle? or just pre 95?
Old 09-04-2009, 08:03 PM
Banned
Call a yard in your area for the interchange,they should have an interchange book called a hollander.
