Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 09-03-2009, 06:01 PM
CutlassOlds88 CutlassOlds88 is offline
98 Bravada Engine
My 98 Bravada's engine has started knocking so I am going to replace it. I called around and found an engine from a 97 Bravada. The guy said that a 96-98 engine would work and a 99-2001 engine would have to be rewired to make it work. Will this 97 engine work in mine?
Old 09-05-2009, 09:20 PM
wafrederick wafrederick is offline
Banned
Re: 98 Bravada Engine
The 1999 to 2001 will fit,the wiring is the same as the 1998.You need the starter bolts and bell housing bolts if you decide to put in the 1999 engine to 2001 because they are metric bolts.I have done them without any wiring harness modifications using the 1999 to 2001 4.3s.The 1997 will fit.
Old 09-07-2009, 02:28 PM
bue car bue car is offline
Funny, my Aunts 98 just started knocking at 46,385
Where can I find a write up on the swap? I bought a new motor from the dealer, and now I need the write up. I just joined here today, help a noobie out
I am on the Subaru forums a lot..same sn.
Chris
Thanks guys!
