Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 09-03-2009, 05:15 PM
r3divory r3divory is offline
95 firebird removing door panel and replacing window motor
I tried to do a search before posting this question. I need to find out how to remove the driver door panel to get to the window motor to replace it. Something is holding the panel into place. I've removed all the screws I can find. Any help would be greatly appreciated.
Old 10-14-2009, 08:36 AM
bradmancue bradmancue is offline
Smile Re: 95 firebird removing door panel and replacing window motor
The door panel actually needs to be lifted up some when removing it. It has some plastic hook like pieces that help hold it in place. When putting it back you will need to line these up again and press the door panel down so they engage. Then replace your screws. Be careful of light wires and speaker wiring. You will pull the out if not careful. I would also suggest that you replace the window motor with a new one. A salvage one will have you replacing it over and over. It seems that these get weak in about 4-5 years. Good luck.
Old 03-02-2010, 09:05 AM
FormulaForce FormulaForce is offline
Don't forget to put those foam pieces back too! If you don't, your door panel may rattle when you drive or play the stereo.
