Rear Axle Hub Bearing Grease
Anyone know what type of grease this is on a 98 Camry? It is white. Ok to repack with regular wheel bearing grease or do I have to clean out all old grease first? Thanks.
Re: Rear Axle Hub Bearing Grease
I'm pretty sure that is a sealed bearing and part of the hub assembly that is not serviceable! How did you see any grease?
They are sealed bearings. They are replaced as a separate unit on non-ABS Camrys and as part of the hub on ABS versions. Easy but not cheap.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. Last edited by jdmccright; 09-03-2009 at 12:39 PM. Reason: typo |
No way I am going to pull the hub apart and I don't have a good way to flush out the remaining grease. Just want to repack and get some more miles. |
Lithium-based bearing greases can be red as well. But if Toy has a specific recommendation, of course you'd be better off following them.
If you have a bearing packer, you might be able to use it with the hub albeit with alot of wastage. Just do your best to spray/blow out the old grease then pack it.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
