Old 09-03-2009, 01:37 AM
maynardc69 maynardc69 is offline
1997 f150 plug wire blows off
Just put new wires(not motorcraft) and plugs on several months ago. I went and pulled a trailer a couple times lately. After the last time pulling it on the way home with no trailer on the #4 plug wire blew off. seems to do it on decellerating. I have crimped it several times and doesnt help. I did have an antifreeze leek above that plug but i tightened it up and checked again lately. It blows it pretty hard out of the hole and behind the block. Any ideas?
Old 09-08-2009, 12:51 PM
FNA FNA is offline
Re: 1997 f150 plug wire blows off
Buy a new wire.
Old 09-08-2009, 03:25 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
You may also have a bad plug, which is leaking compression gases around the insulator. So replace that spark plug, too.
Old 10-02-2009, 10:04 AM
dfordski's Avatar
dfordski dfordski is offline
[q I did have an antifreeze leek above that plug but i tightened it up and checked again lately. It blows it pretty hard out of the hole and behind the block. Any ideas?[/quote] What hole???? You overheated maybe? head warped/cracked/other related boo-boo. Water does not compress. Your plug hole threads stripping out is a possibility.
