Old 09-02-2009, 11:53 PM
braybrax330 braybrax330 is offline
Post Stalling/Sluggish Acceleration..P0134/P0130
My 04's TB's SES light came on over the weekend & has begun to stall at stops after anything more than 5-10 mins of driving. TB will run just fine after start up initially or even a re-start, until you drive about another 5-10 mins, then the issue seems like it creeps back up. When issue occurs the engine begins to shake & you can feel it get worse as you come to a stop. Acceleration is very shaky as well as though the engine is sputtering. Additionally, my A/C & circulation button will not stay lit, instead they flash a couple of times once pressed then go back out....I took TB to AZ & my codes were P0134 & P0130. AZ seemed to think that those codes pointed to o2 sensor but based on symptoms tough to believe that my root cause
Old 09-12-2009, 11:51 AM
Lightbulb Re: Stalling/Sluggish Acceleration..P0134/P0130
Somebody, anybody
Old 09-25-2009, 10:40 PM
bootleg233 bootleg233 is offline
Again I bet this is it:::::::CAM ACTUATOR SOLENOID
NOT I repeat NOT sensor.
Old 09-26-2009, 10:57 AM
maxwedge maxwedge is offline
A990 racer
Those codes point to o2 sensor issues, though.
Old 09-26-2009, 04:57 PM
Well replace them and then when it does it again like it seems everyone is doing or has done then might have to look elsewhere. Just my 2 cents worth and that aint saying I know anything but good luck.
Old 09-27-2009, 10:01 AM
A990 racer
What you suggest may be an issue, but when scanned with a high line scanner the operation of that component can be monitored, stops guess work, in the mean time that code points to an issue with #1 sensor, not " all" of them.
