Old 09-02-2009, 10:29 PM
Ron21 Ron21 is offline
99 Escort ZX2 2.0L DOHC code 1383
Anyone know what code 1380 and 1383 are
I just changed the timing belt and now I keep getting these codes
Thanks in advance
Old 09-02-2009, 10:58 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 99 Escort ZX2 2.0L DOHC code 1383
Sounds like you didn't get something right with the exhaust cam. Those codes are for the VCT solenoid and cam over retarded I think. Did you lock the cams with the tool? When you took of the old belt did you rotate the exhaust cam at all?
Old 09-02-2009, 11:40 PM
I locked the cams with a bar. I had to rotate both cams counterclockwise until the slots were lined up to put the bar in place
Old 09-03-2009, 11:17 AM
Airjer_'s Avatar
With or without the timing belt in place. Without would be bad!
Old 09-03-2009, 11:49 AM
It was without the belt as the old one had fallen off from the top pulley falling apart. I have a feeling I need to pull the exhaust cam gear off and line up some tab with a hole. Am I on the right track?
Old 09-03-2009, 12:16 PM
Airjer_'s Avatar
I've never had to do that myself but I think that is your next step.
Does it run? Like normal?
Old 09-03-2009, 01:02 PM
Yup its running good seems to have lots of power. Little rough when idling and thats when the light comes on
