Old 04-05-2003, 11:00 AM
cap232r cap232r is offline
Question stealth vs. integra r
Could my stock base model stealth with exaust take a stock acura integra type-R?
Old 06-04-2003, 05:57 PM
500hpvr4's Avatar
500hpvr4 500hpvr4 is offline
Send a message via AIM to 500hpvr4 Send a message via Yahoo to 500hpvr4
I dont think so, but he wouldnt murder you, it might be close. Give it a try and let us know what happens. Good luck with the race.
Old 06-04-2003, 05:59 PM
500hpvr4's Avatar
Are you a member of 3si? If not you should check it out, they have the most info about our cars.
Old 06-04-2003, 06:17 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
No.
An Integra Type R will thrash a base model Stealth ES.
Old 06-04-2003, 06:39 PM
500hpvr4's Avatar
Well a base stealth has about 164hp and a type-r has about 190hp. If the stealth has exhaust and a manual transmission he shouldnt be murdered to bad. Just hope the type-r cant drive. lol.
Old 06-05-2003, 12:18 PM
chansigril chansigril is offline
actually a base stealth and stealth es are two different cars. the type r shouldn't have too much trouble with a base (sohc), but an es (dohc) would be a bit more of a challenge, although the type r would prob win out since it has a better weight to hp ratio, all else being equal.
- mike
Old 06-05-2003, 02:49 PM
500hpvr4's Avatar
As far as I knew a ES/Base is a SOHC and a R/T is a DOHC and a R/T T/T is a DOHC twin turbo. Same as a 3000gt is SOHC and SL DOHC and VR4 is a twin turbo.
Old 06-05-2003, 04:02 PM
no 3000's came with the sohc motor, those were only found in the base model dodge stealths.
all es came with the same dohc motor that the rt came with, putting out 222hp.
so:
stealth, base - 164 sohc
stealth, es - 222 dohc
stealth, rt - 222 dohc
stealth, tt - 300 (320 2nd gen) dohc
3000, base - 222 dohc
3000, sl - 222 dohc
3000, vr4 - 300 (320 2nd gen) dohc
3rd gen (97-99) 3000's had slightly different hp numbers, but still no sohc.
only differences between an es and rt (and a base and sl for 3000) were trim and options.
safe travels.
- mike
Old 07-06-2003, 06:43 PM
oolMARKloo oolMARKloo is offline
Send a message via AIM to oolMARKloo
wrong
later base 3000gt's had SOHC
[email protected]
1st time at the track
Gutted pre-cats, test pipe, intake
Old 02-14-2004, 06:32 PM
boosaddict boosaddict is offline
Re: stealth vs. integra r
i have a 1991 dodge stealth and it keeps on getting hot when i am driving but it does not get hot when the car is stopped it has a new water pump what can i do
Old 02-15-2004, 08:23 AM
500hpvr4's Avatar
It gets hot when your driving, but not when your stopped?? Please explain more. How hot does it get? How many miles does the car have? What type of stealth do u have? Is there enough water in the radiator?
Old 02-15-2004, 11:09 PM
i drive it for 15 to 30 minutes and it gets really hot there is water in the radiator even if i drive slow or cruise in the highway.
Old 02-16-2004, 09:04 PM
HotBoys09's Avatar
HotBoys09 HotBoys09 is offline
Send a message via AIM to HotBoys09
NO WAY IN HELL, will a base model stealth beat a Type R! I used to toy with this one guys base stealth with my probe GT. And I was having enough trouble beating the GSR's around here (Sometimes lose) Before that he said it was a RT/TT, yeah with 5-speed, and sohc on the engine. But anyway no deal...
1999 Plymouth Breeze
1995 Ford Probe GT - R.I.P.
1987 Dodge Daytona Shelby Z
WTB 98+ Formula/TA or Z28
Old 02-26-2004, 03:26 PM
N/A-SAVAGE! N/A-SAVAGE! is offline
well guys the stealth AND 3kgt both had three typs of engines.
91-93 setalth: 3000GT:
base= SOHC base=DOHC
ES= DOHC sl=DOHC+ other junk
RT TT= DOHC TT vr4 DOHC TT
94-96 stealth: 97-99 3000GT:
base= SOHC base= SOHC
RT= DOHC sl= DOHC+other junk
RT TT= DOHC TT vr4= DOHC TT
i hope this helps!
P.S bring the type R i'll eat it for lunch
Old 02-27-2004, 06:14 PM
Nesryn Nesryn is offline
Send a message via MSN to Nesryn
Sorry man, he'll beat you though. I keep even with a Type R and I got an 3000gt SL.
