Old 09-02-2009, 05:18 PM
laxman21's Avatar
laxman21 laxman21 is offline
How to replace the multifunction turn signal
First undo the trim around the steering wheel. You need a 25 torx and another driver for the other torx screw. Also nee to remove lower panels and instrument cluster cover. Plus you will need zip ties to replace the ones you need to cut.
New(junk yard) and old one
Unscrew the harness. The plugs to the MFS push out the bottom, so you have to unscrew this.
Torx screws that hold in place
Just turn the steering wheel to get to the bottom one
Other plugs on steering column that need to be changed
Opps
I replaced it because the blinker relay was clicking all the time.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
