Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-02-2009, 06:56 AM
ecamc ecamc is offline
Send a message via AIM to ecamc
Angry Oil drain plug size - '99 Neon
Can anyone tell me the size of the factory oil drain plug on a '99 Neon. I tried a 12mm socket (too small) and a 14mm (too big), so I'm guessing it's either a 13mm metric, or possibly a 9/16 standard?
My son took his car to Jiffy Lube for an oil change, and they appear to have put lock tite on the plug, and I didn't have the appropriate wrench handy, and before I booger it up too badly with vise grips (which didn't work initially), I want to buy/borrow the correct sized wrench/socket.
Thanks!
Old 09-14-2009, 07:31 AM
denisond3 denisond3 is offline
Re: Oil drain plug size - '99 Neon
It wouldnt be a 9/16", so if its smaller than a 14mm, the 13mm would be it. (I am too lazy to go outside and run the car onto ramps to see what it is on our 97). You should use a 6 point wrench, not a 12 point wrench, and if its been put in really tight - its likely time to replace the plug with a new one. The thread is M14 x 1.50 I believe. The drain plug is one of the hex head items on the car that gets a lot of use; like being removed 20 to 30 times in 150,000 miles. So if the hex head or the threads are worn/mushed, or the plastic gasket under it is crushed, a new drain plug helps. Auto parts stores usually carry them, in one of the bubble packs they hang along the walls. Most of them also carry the plastic washers too.
And you shouldnt need to overtighten it, as is commonly done.
Old 09-14-2009, 07:43 AM
Oldsmobile Doctor Oldsmobile Doctor is offline
I use a 13 mm 6 point socket when I run into one that has been over tightened. If it is chewed up you may have to tap (not beat) the socket on and have a new one ready. The replacement from Auto Zone has a 17 mm head.
