Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-02-2009, 12:01 AM
newgstowner newgstowner is offline
Angry gst stumbles in second gear??? help
Just bought a 97 gst but it stumbles in second gear when boost starts to climb. please any suggestions? driving me crazy!!!!
Old 09-02-2009, 12:55 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: gst stumbles in second gear??? help
We need a little more detail in order to help you.
Is the car stock?
What exactly do you mean by stumble? Explain the car's hiccup a little more thoroughly.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 09-02-2009, 05:31 PM
Angry Re: gst stumbles in second gear??? help
it stutters when accelerating through second and third gear. the car is stock except an aftermarket blow off. i though it could be high speed glazing but still happened after replacing plugs, though it could be a boost leak but still happens after replacing blow off and checking for any leaks.
Old 09-03-2009, 09:10 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
What plugs? What gap?
Kris
2012 Genesis Coupe 2.0t
Old 09-03-2009, 10:14 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Is the BOV recirculated?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-03-2009, 10:15 AM
This. And is it the crappy plastic stock one?
Kris
Old 09-04-2009, 10:27 AM
the spark pluggs are NGK and are gapped at .028 the blow off is not stock as mentioned above and not recurculitive, but as i mentioned i dont think it is the blow off anymore cuz the problem still exists after replacing it and checked for any leaks, also no vacuum leaks. thats why i am kinda stumped. i also put feul system cleaner in it, a k&n filter and a new feul filter. whats next? do i change all the injectors cuz that seems a lil drastic but it is starting to piss me off. please help!!!!!!!
Old 09-04-2009, 10:28 AM
What aftermarket, non-recirc valve is it? Should I even do into the "you MUST recirc" speech?
Kris
Old 09-04-2009, 10:32 AM
dont need the speech learning more everyday. bought it third day i had car, first turbo and all, dont have the money to replace it yet but plan to now that i know a lil more. it is a performance dynamic inc. open are blow off valve. work great for what it is and have no problems with car other that same ole stutter in second and third.
Old 09-04-2009, 10:34 AM
You can't say you have no problems other than "this problem". LOL
Until you at least borrow a BOV from someone that mounts to whatever flange you have, you're chasing your tail.
What spring is in this BOV? How does it seal itself internally/to the flange? I've been in the game for 13 years and never heard of this maker.
Kris
Old 09-04-2009, 10:58 AM
ok well thats not that comforting about the blow off. cant say about the spring but will find out when get home and it seals internally. still no leaks and same problem existed prior to installation so would it have anything to do with it.
Old 09-04-2009, 11:00 AM
How high have you boost leak tested the system, and what boost are you running?
Kris
