Old 09-01-2009, 05:50 PM
sup2jzgte sup2jzgte is offline
Remote Starter installation help
Ok so I'm going to attempt my first auto starter install on my 99 Chevy Prizm, the starter is a Valet 551R. Now the car does not and never has had an alarm or starter installed in it before. So far I have printed the wiring diagram from here and have been reading the manual. I would just like to make sure that I have the proper wires going to the proper places. The stuff in bold and parenthesis is what is found on the cars wiring
Valet Wiring Harnesses
H1 Primary Harness:
Black Ground Wire - (Ground to Chassis)
White/Blue: (-) Activation Input - (Momentary switch)
Light Green/Black: (-) Factory Disarm - (Blue/Red (-)-Factory Disarm)
Yellow: (+) Ignition output to security system - (Not Used)
White: (-) 200mA Light Flash Output - (Red/White(-) - Head Lamp )
Gray/Black: (-) Wait to start - (Not Used)
Light Green: (-)200mA Door Lock OutPut (Blue/White(-)-Door Lock)
Light Blue: (-)200mA Door Unlock OutPut (Blue/Yellow(-)-Door Unlock)
Heavy Gauge Relay Satellite Wiring
Red: (+)High Current 12V Input (White or Black/Red-Constant 12V+)
Pink: (+)Output To Ignition Circuit (Black/White-Ignition)
Orange: (+)Output To Accessory Circuit (Black/Yellow-Accessory)
Purple: (+)Output To Starter (Red-Starter)
Pink/White: (+)Ouput To Second Ignition Circuit (Blue/Red-Ignition 2)
Remote Start Harness H2:
Blue: (-)200mA Status/Factory Security-Arm Output (Not Used)
Blue/Black: (-)200mA Optional Third Ignition Ouput (Not Used)
Gray: (-)Hood PinSwitch Shutdown Wire (Not Sure Need Help)
Brown: (+) Brake Switch ShutDown Wire (Green/White-Brake Switch)
Violet/White: Tachometer Input Wire (Black-Tach, not sure where location is)
Black/White: (-)Neutral Safety Switch Input (Red-Neutral Safety Wire....Red has already been used for starter, need some help here)
Here is a screen shot of the cars diagram:
Ok so is what have correct, if I missed something or did it wrong please correct me. Also
Now this is my first time installing a Remote starter, but not my first time working on car electronics.
