Old 08-31-2009, 01:14 PM
raychoate76 raychoate76 is offline
Send a message via Yahoo to raychoate76
Question Hub Bolt
Hey by chance does anybody know what size the hub bolt is on a 1998 cav Z24 with an A/T ? I live 60 miles from the nearest parts store so I am hoping to be able to order everything online for it rather than running the risk of blowing the already failing C/V on the trip to the parts store any help would be appreciated thanks.
Old 08-31-2009, 07:07 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Hub Bolt
2004 is 30mm, I'm 99% sure yours is the same.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-01-2009, 08:46 PM
PlanetDude PlanetDude is offline
Re: Hub Bolt
Having just done wheel bearings this past weekend on a 98 Z24....
I used an 1 1/8 deep socket, and it was a rough fit on the nut on the car, and perfect on the one on the box. 30mm would probably have been perfect on the one the car had.
You`ll need a breaker bar. A big one. Unless you have air tools.
If you`re gonna do the bearings too, or need to yank them for clearance, make sure you have a t55 torx bit. I had to borrow one. That`ll be my next investment.
Again, get an adapter to go from 3/8 to 1/2 drive for that torx bit to go to your breaker bar. Unless they`ve been out recently, they`ll be a fight.
Ryan
Mine:
89 Honda Prelude Si - 2.0, 5-speed
98 Chevy Cavalier Z24 - 2.4, auto
Family`s: (which I do the work on)
05 Chevy Impala - 3.4, auto
02 Pontiac Grand Am - 2.2, auto
01 Chevy Silverado - 5.3, auto
92 GMC Sierra - 5.7, ext cab, auto
88 Chevy Celebrity - 2.8, auto
