Go Back   Automotive Forums Car Chat > Chevrolet > Colorado
Old 08-31-2009, 12:19 PM
koolwhizzer koolwhizzer is offline
Colorado A/C Compressor not cycling on and off
I need help. My 2005 colorado has A/C and i have been noticing that the compressor for the air conditioner is not cycling off and on like all my other cars. This leaves me with the problem of my coil getting frozen and therefore having restrictive air flow in the cab of the truck. I also notice way more that usual condensate coming from the vehicle when the vehicle is parked and shut off. The condensate water runs from the front of the vehicle to six feet past the rear bumper. My question to you is what i should do to fix this problem. Should it cycle off and on? Or is something wrong with a sensor that tells it to shut off and on while running. Please advice??
Al
Old 08-31-2009, 02:36 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Colorado A/C Compressor not cycling on and off
Replace the cycling switch on the low side line- you have described evaporator core freeze-up exactly as it happens......something is causing the compressor to run full time and it most likely is the cycling switch-- a low pressure reading on a gage set will confirm.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 08-31-2009, 04:12 PM
Hi and thanks for your advice. Is this vehicles compressor supposed to cycle off and on. I just had a gentleman PM me and said some models do not cycle. This sounds alittle strange to me. Most vehicles cycle. Please let me know but i think i already know the answer. I am not an air conditioning guy but where do i find the cycleing switch you mentioned. Sounds like somewhere for me to start anyway.
Al
Old 08-31-2009, 09:04 PM
Hi again,
I located the cycling switch on the low pressure side. I unpluged it and it stopped, i plugged it in and it runs. How does this switch come out so i can replace it? Will i lose freon when i change this switch or does it just unscrew and i screw in the new one.
Al
Old 09-01-2009, 10:23 AM
brcidd's Avatar
Sorry- I misled you- your Colorado uses an evap temp sensor to cycle your compressor-- not a pressure switch- that switch you unplugged is probably the 3-wire high side pressure transducer-- not a switch- not your problem here.
Your evap temp sensor is either not reading the proper temperature, because it is bad, or has fallen away from the evap face-- a scan tool will show you the evap sensors exact temperature reading-- and you can watch it as the system runs- and should be cycling off before evap freezes....It takes a "good" TechII to read this-- you will need to find some one with one..
'99 GMC Yukon
