Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 08-31-2009, 10:53 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Where to get the scew fasteners for the hood/trunk?
Well it finally happened... after posting about how I had no trunk lid problems one of the screw fasteners loosened up and came out allownig the T-handles to come loose... that sure looked good flapping behind me on the front straight at VIR and of course it happened right after the entrace to pit road so I had to do a whole lap slow.
I need to replace the one and get some spares. The body work has provisions for a screw fastener on each side and 3 accross the top. We're not using the side ones so I'll drill those out too.
Old 08-31-2009, 11:03 AM
panozracing's Avatar
panozracing panozracing is offline
Re: Where to get the scew fasteners for the hood/trunk?
Pad
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 08-31-2009, 11:09 AM
PanozDuke PanozDuke is offline
I use hood pins and clips on right angle brackets fastened to the wing supports. No way it's coming off
Mike
Old 08-31-2009, 11:13 AM
Cobra4B's Avatar
Originally Posted by panozracing View Post
Pad
Figured...
Mike
Pics?
Old 08-31-2009, 03:18 PM
NZGTRA17 NZGTRA17 is offline
I wouldnt bother buying anymore of the screw fasteners Brian. It will just happen again.
Just swap over to Dzus fasteners on the leading edge and problem solved. This is what I did after the first time out in the car when my "bootlid air brake" activated.............
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 08-31-2009, 03:27 PM
Cobra4B's Avatar
I like that... maybe we should make it controllable from the cabin. I'd be like the bugatti veryon!
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
