Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-31-2009, 12:32 AM
JDnL JDnL is offline
99 MGM, White smoke = Coolant = Head Gasket/Cracked block
1999 Gr Marquis, 4.6L, V8... Lots of white smoke and condensate ("condensation") from both tailpipes. I know white smoke is indicitave of coolant getting into places it shouldn't be and Im told that its undoubtedly a head gasket issue or cracked block.
As w/ many of us, in this economy, there is NO POSSIBLE WAY I can afford to have either of those repairs done... Is there ANYTHING I can do, chemicals/stop-leak products, etc; or something else to subdue the impending death of my ol' girl (and the beginning of my using public transit)?!
Old 08-31-2009, 10:09 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 99 MGM, White smoke = Coolant = Head Gasket/Cracked block
Welcome to the forums.
As far as I know there are no chemicals or fixes-in-a-bottle that can withstand the pressures seen in a cylinder to fix a bad gasket or cracked block. It is more likely the head gasket. Is there coolant in your oil and oil in your coolant? Both may appear similar to a milkshake color.
If it is a head gasket, there is always the option to perform the job yourself. The gasket can be purchased for around $70. If you have some basic tools, basic mechanical skills, and some spare time, you can perform this job yourself by removing the intake manifold and head that needs the replacement gasket. The engine does not need to be removed from the vehicle, either.
Although performing this job can be accomplished as long as directions are followed, it is usually easier to just swap in a new motor. They can be purchased used from junkyyard around $500-$1000 depending on miles and condition of the engine.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
