Old 08-30-2009, 08:54 PM
muff34 muff34 is offline
no driver side power window
hi guys,
2005 grand caravan.problem no power window on drivers door. the window worked fine till today. now there is nothing,the fuse is fine other windows work fine as well. when you try to put window down the dash and interior light will flicker indicating power seems to be going to or possibly thru switch to motor. any ideas would be appreciated
thx
Life Is A Highway ,Enjoy The Ride
Old 08-31-2009, 03:01 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: no driver side power window
The window motor is probably toast. Sometimes you can hold the switch and slam the door to get it going again. You're probably going to have to replace the motor. Most just replace the whole window regulator assembly meaning the motor, cables and window rails as an assembly. I've read of some who just replace the motor brushes for a few dollars. Regulator assemblies can be had for as little as $50. Around $100+ at the dealer. Should first verify the motor is getting power using a multimeter or test light.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-31-2009, 08:09 PM
testing for power at motor. Is the motor grounded thru the door? two wires at motor ,does one put it up the other wire for down or is one of wires the ground?
thx muff.
Old 09-01-2009, 01:40 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
One wire for up one for down. The switch just reverses direction of power through the motor. Ground is via the switch panel. Single ground for all window switches so your ground is good.
Old 09-03-2009, 10:22 PM
ok thank you
Old 07-20-2010, 10:18 PM
rbajjk rbajjk is offline
RIP,
I had to post a THANK YOU for the "hold the window switch down and slam the driver door" suggestion that solved my driver window problem - at least for now. I have a 2004 T&C Limited and the door locks have been intermittent and today my wife told me that the driver door window would not go down. The locks we can manage, but the window....no way. I have read other great advice here and so looked again. I turned the key to acc and sure enough the passenger window would open and close but the driver would not. I opened the door to see if the light would dim slightly when I hit the driver window switch (indicating that the switch was good), which it did. I then shut the door with the switch engaged and nothing. I was about to come back in and start pricing regulators and motors for the window. But, I thought, what have I got to lose with one more harder slam of the door. Well, wham the door closed, and the pleasant whirring sound of the window coming down ( and going back up) was heard.
THANKS, THANKS, THANKS.....again.
Brian
Old 07-21-2010, 12:30 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
rbajjk - Happy to hear it worked for you. Most of the time it's temporary but I have read of it being a permanent fix a couple times. Hope you're in the latter group.
Old 07-27-2010, 09:00 AM
fatjoey666's Avatar
fatjoey666 fatjoey666 is offline
Mine did the switch and smash trick too. Lasted a few weeks, then had to replace the motor. very easy job to do and not very expensive either. I went and got a motor from the U-Pull it yard for $5.00 and it works great! I think They're around $50.00 from auto parts stores! Good Luck!
Old 07-28-2010, 02:37 AM
soyelmismotony soyelmismotony is offline
mine if slamming dont work I push window down enough window will work again.. any ideas...?
