Old 08-30-2009, 08:36 PM
dirtbikeryder45230 dirtbikeryder45230 is offline
99 silverado u1041 code
installed new starter' went to rehook battery starter engaged n cranked had too refix wires on starter, truck didnt run after that cranks fine scanned came up with a u1041 code found no spark installed new crank sensor nothing found low voltage at crank sensor.... any ideals ???? pcm blowed ???
Old 08-31-2009, 10:18 AM
j cAT j cAT is offline
Re: 99 silverado u1041 code
step one check all fuses with a meter..
Old 08-31-2009, 09:22 PM
thanks for the reply found the problem had wire come out of terminal end of connector at crank sensor
Old 08-31-2009, 09:26 PM
that code is a comunication error so the pcm with no engine rotation signal will not create spark..
some have found corroded connections there..
