Go Back   Automotive Forums Car Chat > Geo > Nova | Prizm | Spectrum | Sprint
Old 08-30-2009, 06:41 PM
davidfon davidfon is offline
91 prism charging problem
have a 91 prism the alternator wont charge battery alternator checked and is good new battery and starter im confused
Old 08-30-2009, 07:11 PM
Mechanix333 Mechanix333 is offline
Re: 91 prism charging problem
Did you check all your fuses? my 90 prism has a trio fuse block right off thebattery post and one of them is an 80 amp fuse for alternator.........then if that is not it then check hot wire coming off the alternator to make sure there is indeed vo;tage coming out of it....somewhere between 13.4---14.4.........if there is then you are losing it somewhere before it gets to battery........if not then you need to find out why the alternator is not getting signal to charge,,,,
