Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-30-2009, 06:02 PM
chuy746 chuy746 is offline
start for short time
1997 crown vic start for short time then act like when running out of gas.
notice that before when open the door the chimes would sound . Now there is no sound and car will not start
Old 08-31-2009, 09:49 PM
driver540 driver540 is offline
Re: start for short time
By wont start, do you mean, wont crank or cranks and wont start? Are your dash light indicators lighting up when key is in the on position? Can you give a little more info, please?
Old 09-01-2009, 06:31 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Sounds like an electrical problem if multiple systems are affected. You should check all fuses (in engine compartment and under dash). Also try to get your battery voltage read.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 09-02-2009, 01:52 PM
Car cranks and lights on dash work battery good new one
cranks and starts but will not stay on pump gas and it just dies
CHECK ALL FUSES WORKING CHECK UNDER DASH FUSE
Old 09-02-2009, 02:11 PM
Well I don't think the chime is related, but based on what you said, it sounds like a fuel delivery problem. When you turn the key on (without starting car) you should hear the fuel pump kick on for about 2 seconds and then turn off. If you do not hear this from the rear of the car, the fuel pump itself or the wiring to the fuel pump is bad.
