Old 04-05-2003, 12:52 AM
Deejay27's Avatar
Deejay27 Deejay27 is offline
Question Windex in paint?
I've heard of people adding Windex to their paints (small amount) prior to spraying. What does this do for the paint?
Jimmy
Current Project
"Tamiya 1/24th scale Enzo"
Completed Projects
"1/12th scale Renault FW14B"
"1/24th scale McLaren MP4/7"
Old 04-05-2003, 01:17 AM
freelunch's Avatar
freelunch freelunch is offline
Windex's used to thin acrylic paints.
Old 04-05-2003, 01:56 AM
Deejay27's Avatar
Hmmm....interesting. I just use 70% rubbing alcohol. It seems to work well and it's cheap.
Jimmy
Current Project
Completed Projects
Old 04-05-2003, 07:15 AM
Vric's Avatar
Vric Vric is offline
hehe why not usinf beer
Old 04-05-2003, 10:20 AM
D[X]P's Avatar
D[X]P D[X]P is offline
Send a message via ICQ to D[X]P Send a message via AIM to D[X]P
r u gus?? lol
just put some windex...
Failure is only the opportunity to begin again more intelligently.
Old 04-05-2003, 10:25 AM
freakray freakray is offline
AF Modelrater
Windex is fine for dark color paints, but for light colors you are actually better not using it as the color of the windex will discolor the paint.
Personally I prefer to use rubbing alcohol or the thinners that is meant to thin the paint.
I don't recommend using Windex to thin Tamiya acryllics.
AF User Guidelines
Old 04-05-2003, 12:45 PM
daggerlee's Avatar
Some people use windshield wiper fluid, and they say the blue discoloration is not noticeable in small qunatities. They say the concentration between alcohol and water is just perfect. YMMV.
Dan
Old 04-05-2003, 11:11 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I use windscreen washer fluid myself, it's very cheap and the colour I use is slightly yellowish which is fine in all colours but white.
Steve a.k.a. Hiroboy
Old 04-06-2003, 03:20 AM
wkma7six wkma7six is offline
Windex (I think the amonia acts as a flow agent) is used to reduce surface tension of the paint and allows it to flow smoothly when applied. I have used it in the past, but I don't airbrush with it anymore. I try to stick to Tamiya thinner when airbrushing their gloss acrylics and I use acrylic lacquer thinner for semi-glosses and flats. I also use regular off the shelf isopropyl alcohol when weather conditions permit-meaning when its warm enough outside and low amounts of humidity in the air.
Gunze acrylic paints can be thinned with iso alcohol or acrylic lacquer thinner.
If you really want to use a flow agent when painting, use a brand called flow aid, which is formulated for acrylic paints. It is clear, so no worries about discoloration. You'll have to be careful with the amounts you use with any flow agent additives as your results may end up with improper sheen to the dried surface. I used the brand Flow aid at work for brush painting with cel-vinyl paints and light airbrushing for cartoon maquettes.
This may post may confuse some readers, but I am answering deejay's question the way I have interpreted it. Sorry to rant on.
Good luck
-Walter
Just finished: TURBONIUM
Rosy the Turbo Beetlehttp://www.automotiveforums.com/vbul...9&goto=2072489
Old 04-06-2003, 04:35 AM
Deejay27's Avatar
Thanks for the info everyone. Walter, that is one sick looking HAMANN 360 SPIDER! Got anymore pics of it?
Jimmy
Current Project
Completed Projects
please help! -paint estimate helpme1234 Auto Collision Network 1 06-19-2010 07:11 AM
Switching To WaterBorne Automotive Paint LearnAutoBody Auto Collision Network 0 04-13-2010 08:10 AM
Pain with Paint!! aonewordname Type 1 1 08-29-2009 09:34 PM
1970 Chevelle Paint job xraab Classic Cars 1 05-24-2009 08:53 PM
New Paint Color "HELP" panteli2011 Thunderbird 3 05-01-2009 01:40 PM
