Old 08-29-2009, 06:31 PM
shawnp1989 shawnp1989 is offline
tire/brake/suspension
iono which one it is
but here is the situation
when i start to go, everything is smooth
BUT
when i reach 40-45 mph...... the car starts to vibrate
if i speed up, it stops
if i slow down, it stops
it is only in that speed variable
so what can cause this
flat spot in tire?
off balance tire?
warped brakes?
bent suspension?
please help
i just got new tires and rotors about 2 months ago
the tires are still under warranty but the people claim by my description that it is not a tire problem, so wtf
im about to take it in, but i don't want to pay $125 for a damn inspection
Old 08-31-2009, 08:40 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: tire/brake/suspension
If you've flat-spotted the tires, it's a possibility. It's also possibly an out of balance tire. Both would typically affect a much wider speed range, but I sure wouldn't say it's impossible that it's either of those.
It's not the brakes, or the problem would only be there when you were on the brake.
Check the steering/suspension. I have seen many loose tie rod ends that cause a vibration in the steering wheel in a very narrow window of speed.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
