Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 08-29-2009, 01:45 PM
slredstorm62 slredstorm62 is offline
Send a message via AIM to slredstorm62
Angry 2002 gmc sierra vibration
my gmc sierra ext.cab has a vibration at 45 on. it can be felt in the steering wheel and the passenger side but not driver seat. i thought it was an axle but i replaced it and still same thing. i had the drive shaft out to change the u-joint. but if it was the driveshaft wouldnt it vibrate the truck??
Old 08-31-2009, 04:10 PM
Re: 2002 gmc sierra vibration
update: i flipped the driveshaft 180degrees and the vibration is still there!! any ideas??
Old 08-31-2009, 07:27 PM
maxwedge maxwedge is offline
A990 racer
Check a front tire for a shifted belt?
Old 08-31-2009, 09:07 PM
lynnboy021 lynnboy021 is offline
only at 45? when does it stop and if u go faster then 45 does it also stop?
Old 09-06-2009, 11:11 AM
jlamson jlamson is offline
Is your truck a 4x4? I had a vibration in mine around 50 mph or so, and found that the front drive shaft U-joint was bad. How are your tires?
--Jim
Old 09-10-2009, 08:51 AM
Bob B Bob B is offline
Some wheels do not balance well using the center hole as the shops do.
I've had two cars that needed to be balanced using an adapter for the lug mounting.
Bob B
